If you keep the stock injectors, keep the stock regulator. If you change injectors get the adjustable regulator. if the stock injectors are clean a flow well, low 12s are no problem with them.
If you want to go 12s, get the car in good running form, take off the cat and put a dump pipe on, get some Drag radials, manual boost controller, and toss in 100 octane. It does not take much to get in the 12s. Figure 18lbs of boost should do it. Depending on how the car launches will be a big factor in ET.
I ended up getting a killer deal on the 50s and turbo, so I went that route. My stock injectors were kind of crappy and I did not want to spend $100 to get them properly cleaned. I might have spent more than I needed, but now I know I can get into the 11's pretty easy. 12s are not that fast anymore. Gotta stay ahead of those LS1s.
