87 GN. Vacuum brake conversion kit from Red Regal T. Completed the conversion today and did not have any major problems. The brake pedal is not as soft as I thought it was going to be. After starting the car for the first time the brake light on the dash did not light so I thought I was ok. I went for a test drive and could feel a difference as to the brakes seemed to brake quicker and stronger. I tried to lock up the tires with a hard press on the brake pedal and they would not lock up. I tried several times at various speeds and they would not lock up. I could never get the PM to lock them up either so I have nothing to compare it to. I did not bleed the brakes after completing because I was lazy.
I have a little side to side play with the brake pedal also.
Any suggestions and what is the pedal suppose to feel like?
Thanks,
Clay
Thanks,
Clay
