I know that you have to use the stock "straps" to attach the 36mm sway bars to the frame, but I got rid of those years ago. Right now I have the straps that came with polyurethane bushings for the stock sway bar. It doesn't seem that I can use those and the stock bushings from the 36mm sway bar.
Should I order the bushings w/ greasable mounts for the 36mm bar???
Thanks!
Thanks!
