Downpipe on the passenger side. Hence polyurethane bushings may not last forever on the passenger side. I think that the brass might be a better idea on the passenger side. Hence polyurethane only on the driver side front end might be the way to go. Sorry that you misunderstood. When I said that area, meant the area that he was referring to, the passenger side. I thought that the sentence down below that fully explained that the downpipe was on the passenger side. Also, there is a heat barrier made out of stainless steel sold by Kirban Performance and everybody else that might restrict/deflect the heat away from the bushings regardless of what material is used for bushings. I am going to look into the Global West set-up when i do bushings.
Work for you now, Bruce?
