I'm glad that the new motor is finally in running condition and soon (Tues) it's off to the body shop. I have been ironing out some minor details....IAC set, TPS set, up-pipe sealed, idles great, new coil / module installed with good gnd, new cam sensor set, new crank sensor set, etc.
Problem is I rev it in park from an idle and I get a slight popping or misfiring when I do so. This happens after it's warmed up for awhile. Did the MAF tap test (passed) and checked fuel pressure - all good. New wires, new plugs. I read a thread after doing a search on this and someone suggested to check the motor to body GND from the head to firewall....
Don't know what else to check...no SES light on either.....
