boostmaster
- Aug 20, 2001
Anybody done it, can it be done?
SignUp Now!Have any pics of this setup?DonWG said:I'm port injecting alky through six home made nitrous port injection nozzles. A bunch of it. If I recall correctly, it's about 80 lbs per hr per cylinder, constant flow, on top of the 160 lb electronic injectors at max 85 percent duty cycle. My research has taught me, it's the best bet for getting equal distribution. It becomes much more important as the quantity of alcohol your injecting rises. Alcohol falls out of suspension easily with the intake temperatures it can produce and the possibility of unequal distribution is not worth the chance. At least in my case. In a gasoline application, where the alcohol is mainly used to lower combustion chamber temperature and not as a main source of fuel, it probably is not worth the plumbing nightmare to port inject it. Besides, the orifice size required to inject such small amounts per cylinder would be hard to keep from getting plugged.
Quiky One said:Have any pics of this setup?
thanks Jason
Alright cool. Sounds like its going to be a slick setup.DonWG said:I'm waiting for a 105mm throttle body to come in so I can mount it to a new upper manifold section that I hammer formed to look like a F1 air intake. It looks cool. I'll post some pics in a month or so.
DonWG said:Spork. I just checked out the pic of your intake setup. I would watch out for a distribution problem when you start increasing your delivery rates at the nozzles. Wouldn't it be best to feed the two distribution manifolds (one to three) by teeing in between them? I see a possible pressure drop problem with the one in the pic. Have you already tested for the future higher flows your planning on?
thanks Jason
Quiky One said:The pics arent working for me. If you email them to me I will host them. Let me know.
Jason
Photobucket...or I could resize them and post them in a thread. Let me know.DonWG said:I'm interested. Where would you host them?
By the way, I just finished loading a shorter full screen slide show.
