Ported Champion Heads, Ported Intake, Billet CAM, Valve Covers, Aluminum Oil Pan, Front Cover
87TurboGN
See Pics or contact me with questions. Prices do not include shipping. 859-312-3184
Comp 236/236 Custom Billet CAM With Hydro Roller Liters, Cam Gear and Button and Bolt- Spec card is available. $600 Used for 300 Miles only
Stock Ported Intake Ceramic Coated with Bolts and Sensors and EGR Block Off plate, PLus EGR was Welded shut PCV Valve locatio was welded shut also, but coul be drilled out if needed.- $275
Champion Fully Ported 14 Bolt Heads with 1.65 Scorpion Roller Rockers, ARP Studs, Bee Hive Springs, Come with original unsed springs also.- These just came off mother with uner 300 miles on them. Mint Condition, Need to be cleaned and you are ready to go. Port work was over $600 by itself. $2000
Used ARP Stud Set - 8 head bolts, Nuts Washers and Bottom End Stud Set, Already stretched and ready to go - $140
RJC Girdle and Hardware - $325
TA Valve Covers with Bolts, Breathers - $125
V6 Valley Pan - $40
Lokar Custom Locking Dip Stick - $60
DLS Aluminum Oil Pan with Screen and Windage With Front High Volume Cover and Dutt Pum Set Up. Includes Oil Lines in Pick Plus Turbo Drain Line $975, Cost was $1200. Perect Comdition.
GTQ 70 Turbo by Limit Engineering - $900 - 300 Miles, Mint.
