Polished Kenne Bell 70mm throttle body, polished 70mm plenum, billet vacuum block, iac, tps, ported lower intake with coolant pipe, sensors, etc. EGR has been removed inside. Still have the EGR to plug the hole in the intake just took it off to clean.
$650.00 shipped
Stock ECM modified by quad air for 55 lb injectors. ECM has a 110 octane chip installed with 26 degrees of timing for the 55 lb injectors. $225.00 shipped.
Excellent working coil pack & ignition module mounted to factory bracket. $225.00 shipped.
Will consider reasonable offers.
$650.00 shipped
