Ported, Polished, Coated Stock Intake
sackracing
Staff member
Stock intake, ported to stock gaskets, egr removed, polished and jet-hot coated. Has an egr block off plate and I will throw in a spacer plate and stainless socket heads for the plenum. 325 + shipping.
I have a Kenne Bell plenum I will throw in for 35 extra bucks if it goes with the intake. I drilled and tapped two npt ports on back side, I can plug them with stainless plugs.
I also have iron heads that are ported to stock gaskets. They have about 1500 miles on them and probably 35+ 1/8 mile passes since they were prepped in 1999. At the time they had new spring installed, new valve guides, polish job and ported to match intake.
sackracing@gmail.com
Where are you located? How much shipped to Chicago 60617 for intake and plenum
I'm in Louisville ky. I'll try to get a shipping price tomorrow.
i am in bowling green are you coming up this weeked for buicks what is the price on the heads
I'll be down this weekend. I'll take 450 for the heads with the ARP studs.
