I want out the road today at 20 psi and the car felt like a 14 car so i pulled the motor apart. I checked the lifters and they are ok , the cam looks to be in good shape to from what i can see , check it better after work.
Any thing that i should check now that its open. I do want to check the rockers , maybe the push rods are to long, they are MPR387 push rods and they look pretty new. Now with this push rods and the 206 cam and comp lifters do you think the push rods need to be shorter. There is a power lose in this car and i will find it or i will pull the motor and go with a 86-87 set up.
