Without any load upon the carrier both axles should turn at the same speed. Only when there is a load placed on the diff. will the passenger wheel become the primary drive wheel....
Dont know if this is what you were looking for.....
Hmmmmm
I tried to turn one wheel with the rear in the air and tranny in park, wasn't able to by grabbing a 26" ET Street. I tried with all my might and couldn't do it. Had to be applying well over 50Lb/Ft. Never seen a posi that tight before.
How bout ya try this...raise the drivers rear of the car leaving the passenger tire down contacting the pavement..So That It Cant Spin..now turn the drivers tire..should take 50ftlbs of torque to do so.If less... the posi is toast..
If it doesnt turn..check to see if someone installed a spool in your rear
