Can someone tell me what fuse is to the fuel pump. I dont think im getting any fuel.Its cranks but no start.Just replaced the 02 sensor and put in new plugs.Thanks
in the fuse box there is a ipr (i think that's the letters) fuse. on the top left side. i had a grounding out problem that kept blowing that fuse and it would crank but no start. don't know if that's ur problem but it's worth looking into.
Check the FP/INJ fuse, and the ECM/IGN fuse. If both those are good, and you are getting power to the ecm (orange wire connected near the battery (+) ) , then either the Fuel Pump Relay is bad (fairly common) or the FP itself has taken a dump (very common). Here's the wiring schematic. Check to see if the pump will run with direct voltage at the connector under the rear bumper..... then you'll have your answer...
