Power Antenna and painting car
I've seen those videos. Bending the fender out and removing bolts in front of door with fresh paint is not something I wanted to do.
you could move the mast though hole just enough to hold it (an inch or so )unplug it .pull the bezel .tape the mast up to the edges of the raw opening and paint it .that way you wouldnt have to remove it and the paint would lay flat to the raw opening
