Power Antenna Cross-Reference
getchasum
MISSING 2 CYLINDERS???
I’m looking to go junk yard diving for a replacement power antenna. What cars came with an identical power antenna? I head that some of the late 80 models that were front wheel drive has the same antenna in the truck. Does any one have a GM cross reference list or know for sure? Post a list of cars if you have it.
80-87 G or B body is a direct bolt in .
if you have a gbody power antenna that has the brackets on it you can use those to mount nearly any gm power antenna from a flat top fender mounted car .
as far as the anntena lead in if it doent match you should be able to use your lead in connector from the original , as long as its not a cb ant
the ones in the trunks usually are relayed (have a relay attached) and i dont know if this is a problem, havent tried them out because the mast ends are different from the original
i got mine from a caprice .
