If the motor is not running and the mast is half way down...Run it back up and inspect for bends or creases in the mast. It may just be stuck... If the mast is bent you maybe able to bend it back, if the mast is creased.... You will have to replace it. I had to replace mine when the cable broke. Real fun stuff!
Originally posted by Lhorn My power antanna works, but only goes half way down. Any idea how this happens, if it is fixable and how I would do it? Thanks
Thanks for the replies. The motor does stop after the antenna reaches half staff. (ie doesn't keep running). It's very straight- not creased. Sounds like I have to change the mast right?
Its will not got down like that because the motor is off. Turn the radio back on and then off, while the antenna motor is running try to push the mast back down and becareful you don't bend it.
