Need help idle goes crazy once warmed up in closed loop
Sean13
Hello everyone,
So once my GN warms up and goes into closed loop my car starts going super lean then normal back and forth afr gauge goes to 20 then back down to 14.7-15.2 some times it dies scanmaster numbers are all in range where they should be as this happens I did a smoke test to try and find vacuum leak but nothing 5.7 chip from turbo tweak can someone point me in a direction to go thanks
The best thing to do is warm engine and post Scanmaster readings
Also give some info of year and any mods
Ok 86 gn 60# 66mm turbo front mount intercooler ls1 map
BLM 125
TPS 0.36
IAC 15
02 149
Mv 722-830
MAF 5-6
LV8 37
INT 128
Volts 13.7-14.1
No codes
BLM 125
TPS 0.36
IAC 15
02 149
Mv 722-830
MAF 5-6
LV8 37
Will do and changing 02 pricing one up now thanks for the help I will let u know
If you change anything like injectors, heads, turbo etc then the chip has to be reburned.
