Power Antenna
aminga
Chicks Dig the powerbulge
Guys.
I reported a couple of months ago that I went out to the garage and heard A buzzing from the PS side of the dash. Another power antenna problem.
I was able to troubleshoot it to the Relay by powering the antenna up and down from the connector under the hood. The antenna moved and cut off when it hit the limit stops so it the motor was fine it must be the relay.
Well it wasn't the relay either. I found the ground broke when I changed it out. Regrounded it and everything is fine.
So simple tip guys if you're getting the buzzing behind the dash check the ground from the relay first.
