at what power level does upgrading DP to 3.5 add gains??? I just bought a set of ATR headers and am thinking about building a custom 3.5 DP out of a TH style upper. Also wil the down pipe clear the headers with the custom TH upper for a hybrid.
SignUp Now!Originally posted by ILBCNU6
A TE-45A isn't stock appearing as it has a one piece inlet bell-compressor housing, a TA-45a is stock appearing. The 45A is already a 66mm compressor wheel and the Q trim is just several more compressor fins added. This info came from Limit Eng. Janes' Engine is a S1 now with all the good internal parts as Reds' is a S2. I wonder why? The "Raptor MAF really helps makes these cars rock plus some good tuning! The first .6 sec, the power level is maxed out! Amazing isn't it! Smooth running cars that run low 10's easy in race trim or faster. I don't know how the 3.5" THDP fits under the heater box, ATR Headers might cause the DP to hit the heater box? Stock manifolds would be easier to fit though. Using the poly motor mounts raise the engine slightly too, so some fitting might be needed. Gene
