Evaddave 87gn
Always learning...
General info leading up to this particular run:
This past spring (2017) I finally spent some time working on issues with my car. I replaced the wastegate that was preventing me from running under 25lbs boost. I fixed a ground issue that was affecting the Maftpro from adjusting the timing. I also set the Maftpro to control boost and timing based on the gear I was in.
Next I started to level out my A/F ratio pulling fuel from my main scale, but I never finished my adjustments before life happened and I stopped going to the track in 2017.
This is the third and last run of the night. On this particular night I was verifying the timing and boost were correcting as I wanted, they were. So on this last run I added a couple psi and left the A/F and timing alone.
My hand logs say I ran 11.21 at 121mph with a 1.745 60'.
Spring 2018 plans:
This winter I am making some changes to the rear suspension, as think I will be able to start to work on my 60' time this spring. I really think I am getting close on my main scale adjustments, so I hope to focus on first and second by adding timing and pulling fuel down low.
Open to any tuning comments. Always willing to learn from others!
Converter questions:
I used the Powerlogger to take a look at my CS% and I could use some advice. I have very little experience with CS.
What should I see when the converter is locked at WOT? 0% or is under 5% acceptable?
I am seeing slip near 39% at times, it this just lost power?.
How does CS effect tires breaking loose at launch?
I am hoping to get 60' below 1.6 or lower, but I am wondering if the current converter will make it difficult.
Any input or advice is appreciated!
Spring 2018 plans:
