Power Logger for Dummies
scrobbyd
Okay, I just got my AEM wideband installed the only thing I have left to do is get the bung welded in first thing in the morning. I also put my Casper’s fuel pressure transducer in and tied into my Power Logger. My question now is how do I get the PL setup to read fuel pressure and what should I look for? As of now I went to the analog setting and selected “Pressure 100psi”. What should I be looking for to know if my transducer is working properly? Also once I put my wideband in I will install my TT6.0 chip, should I disconnect the original O2 sensor or what should I do with it? Basically I need help getting started/”Power Logger for Dummies”. I do plan or doing plenty of reading, however the info I’m asking about wasn’t in any of my instructions nor have I found any threads pertaining initial setup/start up info. Almost forgot, in MAF config on Power Logger what do I need to select if I have a 1st generation translator with I think LT1 MAF sensor?
Thank you for any and all guidance
6.0 chip
I use a 6.0 tt chip and the wideband is only for wot fueling. The stock o2 sensor still controls idle and cruising
Power Logger seems to be working fine, everything but my fuel pressure transducer from Caspers. I do not know what to do in order to make it work. I tested voltage on my pig tail which is correct 12v. I've have my 5v signal wire in the #4 position on my Power Logger analog. I've tried the Pressure 100psi, Pressure 100psiB and Pressure4 on my analog input settings drop down. The voltage on wideband are showing 4.80, 3 bar sensor 1.60, the rest are reading 0.2. Do any of you guys have any idea of where do I go from here? FYI, I have 2 brand new Tranducers and I'm getting the same results with both of them.
On the input: #4 or I4. They are different. You need I4. Just making sure.
Eric
Ok Eric at least I'm getting something now graph is reading 16.2 to 1.5 but moving around quite a bit. I know my pressure is at 43psi line off and about 36 line on. So where do I go from here? FYI Bob said either 4 or 5 would be fine
Thanks for the info, still trying to figure out how to post a file from Power Logger
