Power Logger software question
Amelio
I may be able to scrape a few dollars to get a logger but the I do not have a laptop....
If I buy the logger and temporarily use my work laptop can I simply transfer the softer ware to another laptop when I can buy one? Or does the software stay on the disc provided and it can be down loaded any number of times?
Also I will not be able to afford a wide band at this point but the logger does record the narrow band o2 and kr correct?
Yes you can use a different laptop. Yes it records narrow band sensor and kr.
ok great thanks! my only concern was transferring the software once I can by my own laptop
the only thing you may want to transfer to your new laptop are any data logs you create... which is easy with a flashdrive or shared network
