Power logger??
KCODE
Purchased power logger already installed in ECM. I have 1986 buick gn w/ digital dash. How do I install in car? I've searched but all I find is how to install PL to ECM and how to install on analog dash cars. Help????
You need to unplug the harnesses from your current ecm and plug in the ecm with the power logger.....As far as the digital dash don't think that will come into play unless you tap into the wiring for the map sensor to read boost on the power logger....
Will need a WB sensor to read AFR and the 2.2 chip to read it through your SMaster
