Was reading in the info guide by Peter Hoffman copy right 2005 pg 48. Keeping the brake fluid absolutely clean won't allow the sludge to form and clog the valve. He states to actually change the fluid every 6 months to keep it absolutely clean.
I thought that was bit excessive. I called and spoke to Dennis Kirban personally to see about another brake assembly as everyone else has as per what they all say. I thought for sure he would just say yes you need this and this. He did' t. He told me that the GM people never told the public about the fluid. He said the same thing as Hoffman. Keep it abosolutely clean and you will not have any problems. That the power master is actually a good system but has to stay clean. I had this conversation with Dennis just a couple of days ago. My fluid was a little dark so I changed it and bled the system clean. I only have 29,600 miles on the car. He said that most people that have had problems were the ones with many more miles than that. There was no muck in the master cylinder bowl before I bled and cleaned it so maybe it'll be ok. I'll work on it as they both suggested. Maybe the power master is getting a bad rap. Guess I'll find out!
