SignUp Now!That bolt was stripped on mine new from the factory.Originally posted by QuickWE4
For what it's worth, be careful when re-installing the upper plenum bolt on the passenger side closest to the firewall (the bolt that has the bracket for the vac line). For some reason, I'm not the only one who has stripped that specific bolt upon reinstallation. Helicoil to the rescue.
Rich
Originally posted by blackbuick87
On mine the passenger side was fine but the stud on the drivers side that holds the throttle linkage stripped. I was able to save it with a longer bolt. What are those supposed to be torqued to? It seems like anything above 20lbs will strip them.
