POWERBRAKEBOB
Banned
- Mar 28, 2005
12.7-1 quick steer box
Well, O.K., I have had drag race cars, and even removed the front brakes to drop weight. It was no longer a street car. Maybe? 5% of G.N.s are now pure drag cars only. Racks still need tie rod ends, and with or without a p/s pump, the car still needs steering parts. Most of the guys on this forum are running street only, or occasional drag use. They still need reliable steering and braking. If you cannot put in enough caster to make the car go straight with a rack, then it is too miserable to drive in daily use. Worm gears will not allow tires dropping into pot holes and lane irregularities to kick back the steering wheel. Racks have nothing to stop kick back from the tires falling into grooves or other road irregularities. Racks need more caster built into the a frames to return to center than a worm gear. It's just my opinion that a 12-1 steering box, with a 1.250" sway bar, and the hydrobooost will make an outstanding, all around great handling car. Drag race is anything you can live with.
