Power seat track assembly
Red Regal T
Senior Member
You can use this assembly on either driver of passenger seat. This is an 87 style assembly, a bolt on, plug and play, which replaced the inferior assembly on earlier Gbody models. I'm offering this for $175 shipped to continental US. If you're contemplating powering the passenger side, I have a button panel to go with it for an extra $15, pictured below.
John,do you need the wider track from a Limited ,i know you like wide seats..
i just pulled one from my limited and it dont fit my bucket seat.....
It doesn't fit, in what aspect? I suspect your Limited is not an 87. All 87 and newer seat tracks have the same distance between the left and right track of each side, whether buckets or 60/40 seating. Also, the power seat tracks will work on either side. They are not opposites. It's the same track with motors in the same position. :smile:
1986 limited the track is about 1.5 inches wider then the bolt hoses of the buckets( left to right)
