incubus2432
Douchebag
- Jun 23, 2006
I am in need of a new power steering pump and am unable to find a "heavy duty" version so my only option appears to be a Cardone rebuilt unit from the local parts store. Which may be fine but I know how rebuilt units can be hit or miss so while poking around Summit I found this.... Summit SUM-340206 - Summit GM Type II Power Steering Pumps - summitracing.com
It looks like the stocker and it's probably just a Cardone unit as well but I can get it quicker and have a gift card I can use to save some $$$$$. I know there are different units that look similar but our's rotate opposite.....how can I tell the difference? And will this one from Summit work? I would assume "no" because it is a universal designed to replace a V-belt Saginaw pump w/ reservoir so it probably spins the wrong way....but it doesn't hurt to check.
