- May 25, 2001
How do you tell if the power steering pump is correct for a turbo Buick application? With the absence of the smooth pulley and the unique pressure hose.
The casting no. 7839999 on the housing is used for several applications. The biggest question, is forward or reverse rotation?
Without putting on a correct application car and running it, is there any other way to see if it's good?
