Power steering reservoir hose to steering pump
"Turbo-T"
V6 on steroids
Mine looks like someone cut it short on the end where it slips over the port on the reservoir. As an end result it's kinked.
Just wanted to know if this hose was/is a special curved hose or if it's some sort of typical hose you can have the counter workers at your favorite parts store cut off of the spool in the back?
Also if it is typical hose, anyone know the size diameter?
Thanks.
Nothing special about that hose as far as I know. It should be 5/8" cut to fit or you can buy part 71351 ... powercraft.
NAPA sells it I believe and it's rated for power steering fluid.
I thought it was 5/16" or 3/8"? :confused:
