Likely Bob but...
Caspers sensor is wired in but not hooked up to anything it is just laying in my engine bay safely. The PowerLogger is seeing 1.5 volts on INPUT4 and the output at the sensor's green wire matches that voltage.
Here are the settings I put into the INI file:
[CustomAnalog4]
CustomAnalog4Name=Fuel Pressure
CustomAnalog4LongName=Fuel Pressure Sensor
CustomAnalog4Tag=FP
CustomAnalog4GaugeMin=0
CustomAnalog4GaugeMax=100
CustomAnalog4GraphMin=0
CustomAnalog4GraphMax=100
CustomAnalog4MinValue=0
CustomAnalog4MaxValue=100
CustomAnalog4MinVolt=0.5
CustomAnalog4MaxVolt=4.5
Now in 'Config and Download' 'Analog 4' with Pressure 100psi-B selected I get 12.9 to 13 psi on the graph. If I select 'Fuel Pressure' I get 24.5-25 PSI.
Which one SHOULD be selected for Analog4?
Is this output at atmosphere about right? (13psi seems right or close to atmosphere given this is a fluid pressure sensor).
Looking forward to your feedback!
Best,
Jeff
[CustomAnalog4]
CustomAnalog4Tag=FP
Best,
Jeff
