Kyleh24
86 GN , 87 White T
- Jan 15, 2014
I am new to the powerlogger, but installed it because I am getting knock. So far I have not hurt the engine, so I cut the boost down to prevent knock. So first a little bit about the car. 87 Turbo-T, TT chip, one size larger turbo (can't remember the number) 3 inch down pipe, K&N filter, adjustable fuel regulator. Now the bad, so to speak: factory injectors, factory fuel pump and wiring. I just bought a new fuel pump and wiring kit, but not installed yet. Trying to run the tank close to empty. Fuel pressure is set to 43 under the hood, but I don't know what it is doing under WOT. I also do not have a wideband o2 sensor. Meanwhile the file here shows right before the knock a fuel injector cycle over 100%. With my limited knowledge, this is a lean condition. Can anyone verify? I feel the next step would be to get my fuel pump installed. I don't want to keep throwing money at it, but what would be next? wideband o2 sensor? extended fuel pressure guage to the hood? Thanks in advance. Kyle
