Hello to all,
I have a new build (86 GN) with about 1,500 miles on it. I have just added the Powerlogger and TurboTweak Alky v6.1 chip. I did a couple runs before the rain hit, (all with no alky) to get a baseline to know where I am before I start trying to tune with methanol. Can I get some feedback from you guys. This is my 1st time really attempting to tune and using the powerlogger.
P.S. I started having some weird things happen with the scanmaster. On the 3rd run, it would show 0.0 for just about all the readouts including mph while I was clearly doing 45mph. I am not even sure if the 3rd run is even creditable since the scanmaster was flaky. Then I started getting codes thrown (Troubles Code 24, Code 21, & Code 22), but nothing was showing up on the scanmaster for the 1st and 2nd run. I always had problems with speedo (It fluctuates while driving and after 45 I have look at the km). I started car today, but no trouble codes.......
thanks in advance
thanks in advance
1st Test Drive (No Alky, 16-17psi)....(Trouble Codes).dat540.8 KB · Views: 24
2nd Test Drive (No Alky), 18-20psi.....(No Trouble Codes).dat573.8 KB · Views: 35
