powerlogger/fuel pressure sender settings?
TA49-WE4
I need to know how to set my fuel pressure sender.
I have my analog 4 input setting on pressure 100psi. It reads 21 psi on the powerlogger however my fuel rail gauge is reading 39 psi.
How do I set it to match the pressure sender specifications I have below?? I can't find anyway to adjust it. The only adjustment I can find is on the f3 page.
I need computer language for the computer dumb please. :rolleyes:
if someone doesnt help you before i get home i will post up. i need to get to my computer to tell you. i want to make sure i got my info right
I did'nt pay attention to the name of the transducer, it seems you have 5volts so it should work for you also. (what brand do you have anyway?) never mind doesn't matter. you have to copy a certain version of the files to read with the logger i think it's version v1.3.22 after you save the file just go in the ini file and adjust your settings... here better yet just read here:
Enjoy,,
Last 2nd and 3rd page worked for me but better yet read it all--
:wink:
Casper's Fuel Pressure transductor - Full Throttle Speed Tech Support
did you download the 1.3.22 version of powerlogger? here is the setting that i have below that are highlighted in red. http://www.fullthrottletech.com/attachment.php?attachmentid=1401&d=1260747448
[Debug]
TurboTweakSD = 1
[Comm]
AutoPort=1
Port=3
GraphSkip=0
FrameRate=18
[Startup]
Page=3
AutoConnect=1
[Graphs]
Graph1Channel=5
Graph2Channel=15
Graph3Channel=18
Graph4Channel=3
[Data]
MAFRangeIndex=0
Barometer=101.300003051758
VehicleSpeedScale=1
ECMReferenceVoltage=4.94999980926514
AFRChartMax=16
AFRChartMin=10
[AnalogChannels]
Analog1=3
Analog2=0
Analog3=0
Analog4=8
Analog5=8
Analog1Filt=0
Analog2Filt=0
Analog3Filt=0
Analog4Filt=0
Analog5Filt=0
Analog1OffsetVolts=0
Analog2OffsetVolts=0
Analog3OffsetVolts=0
Analog4OffsetVolts=0
Analog5OffsetVolts=0
[DisplayConfig]
AnalogSpark=0
[Custom]
LV8Gauge=4
[ScanmasterConfig]
DisplayWB=1
DisplayMAP=1
DisplayBoost=1
DisplayEGT=1
DisplayAutoBaro=1
[Triggers]
TPS=3
KNR=10
MinRecordingSec=10
TPS_TrigEnabled=0
KNR_TrigEnabled=0
NewDTC_TrigEnabled=0
[QuickSave]
DefaultFilename=QuickSave
DefaultComment=Quick Save File
FileSerialNumber=0
AutosaveAfterRecording=0
[ConverterSlip]
RatioLowGear=0
RatioMidGear=0
RatioHighGear=0
[Warnings]
KnockWarningThreshold=2.5
RPMWarningThreshold=5500
[CustomAnalog4]
CustomAnalog4Name=Alky pressure
CustomAnalog4LongName=Razor's Alky Pressure
CustomAnalog4Tag=Alky
CustomAnalog4GaugeMin=0
CustomAnalog4GaugeMax=150
CustomAnalog4GraphMin=0
CustomAnalog4GraphMax=150
CustomAnalog4MinValue=0
CustomAnalog4MaxValue=150
CustomAnalog4MinVolt=0.5
CustomAnalog4MaxVolt=4.5
[CustomAnalog5]
CustomAnalog5Name=Fuel Pressure
CustomAnalog5LongName=Fuel Pressure
CustomAnalog5Tag=Fuel
CustomAnalog5GaugeMin=0
CustomAnalog5GaugeMax=150
CustomAnalog5GraphMin=0
CustomAnalog5GraphMax=150
CustomAnalog5MinValue=0
CustomAnalog5MaxValue=150
CustomAnalog5MinVolt=0.5
CustomAnalog5MaxVolt=4.5
[Debug]
TurboTweakSD = 1
[Comm]
AutoPort=1
Port=3
GraphSkip=0
FrameRate=18
[Startup]
Page=3
AutoConnect=1
[Graphs]
Graph1Channel=5
Graph2Channel=15
Graph3Channel=18
Graph4Channel=3
[Data]
MAFRangeIndex=0
VehicleSpeedScale=1
AFRChartMax=16
AFRChartMin=10
[AnalogChannels]
Analog1=3
Analog2=0
Analog3=0
Analog4=8
Analog5=8
Analog1Filt=0
Analog2Filt=0
Analog3Filt=0
Analog4Filt=0
Analog5Filt=0
[DisplayConfig]
AnalogSpark=0
[Custom]
LV8Gauge=4
[ScanmasterConfig]
DisplayWB=1
DisplayMAP=1
DisplayBoost=1
DisplayEGT=1
DisplayAutoBaro=1
[Triggers]
TPS=3
KNR=10
MinRecordingSec=10
TPS_TrigEnabled=0
KNR_TrigEnabled=0
[QuickSave]
FileSerialNumber=0
[ConverterSlip]
RatioLowGear=0
RatioMidGear=0
RatioHighGear=0
[Warnings]
[CustomAnalog4]
[CustomAnalog5]
My powerlogger is brand new. I don't know what version it is. How do I tell? Where are you coming up with all those settings posted above? I can't find any adjustments except on the f3 page.
Also how do I access the ini files? Where are they?
open up powerlogger and go under help and click on the bottom where it says "ABOUT PLC" it will tell you the version. yours is probably 1.3.11 when you download the new one just copy over the files under powerlogger file. your new settings will be in ini file which will say "PLC configuration settings 2 kb. click on this and it will be on the bottom. you can change the name in the first two lines to say what you want on your display. it will be in the config and download page under analog 4 and 5. also if you have a wideband and want it to display wideband correction copy my first two lines where it says turbo tweak debug. and it will display this on your graph as well as gauges. another thing if you have alky on your car you can use this to read alky pressure and name this also in either analog 4 or 5. with a transducer of course. when you are done making changes to the ini file make sure you save file to keep your changes you made
Its version 1.3.3 is that newer than the 1.3.22 update?
Where is "PLC configuration settings 2 kb. at?
I see where wideband correction is listed on analog 4 and 5.
Ok I found "PLC configuration settings 2 kb.
This is what mine reads.
[Comm]
AutoPort=1
Port=4
GraphSkip=0
FrameRate=20
[Graphs]
Graph1Channel=0
Graph2Channel=10
Graph3Channel=13
Graph4Channel=3
[Data]
MAFRangeIndex=0
Barometer=100.500003051758
VehicleSpeedScale=1
AFRChartMax=16
AFRChartMin=10
[AnalogChannels]
Analog1=3
Analog2=0
Analog3=0
Analog4=3
Analog5=0
Analog1Filt=3
Analog2Filt=0
Analog3Filt=0
Analog4Filt=0
Analog5Filt=0
[DisplayConfig]
AnalogSpark=0
[Custom]
LV8CoolantGauge=0
[ScanmasterConfig]
DisplayWB=0
DisplayMAP=0
DisplayBoost=1
DisplayEGT=0
DisplayAutoBaro=1
[Triggers]
TPS=3
KNR=10
MinRecordingSec=10
TPS_TrigEnabled=0
KNR_TrigEnabled=0
[QuickSave]
FileSerialNumber=0
[ConverterSlip]
RatioLowGear=0
RatioMidGear=0
RatioHighGear=0
[Warnings]
KnockWarningThreshold=0
[Comm]
AutoPort=1
Port=4
GraphSkip=0
FrameRate=20
[Graphs]
Graph1Channel=0
Graph2Channel=10
Graph3Channel=13
Graph4Channel=3
[Data]
MAFRangeIndex=0
VehicleSpeedScale=1
AFRChartMax=16
AFRChartMin=10
[AnalogChannels]
Analog1=3
Analog2=0
Analog3=0
Analog4=3
Analog5=0
Analog1Filt=3
Analog2Filt=0
Analog3Filt=0
Analog4Filt=0
Analog5Filt=0
[DisplayConfig]
AnalogSpark=0
[Custom]
LV8CoolantGauge=0
[ScanmasterConfig]
DisplayWB=0
DisplayMAP=0
DisplayBoost=1
DisplayEGT=0
DisplayAutoBaro=1
[Triggers]
TPS=3
KNR=10
MinRecordingSec=10
TPS_TrigEnabled=0
KNR_TrigEnabled=0
[QuickSave]
FileSerialNumber=0
[ConverterSlip]
RatioLowGear=0
RatioMidGear=0
RatioHighGear=0
[Warnings]
no yours is the first version you need to download the 1.3.22. the wideband correction is not in the analog section that is something else
Your FP settings are for 100 PSI, your sender is 10bar=150 PSI. So the calibration is different.
That is why you need to change the calibration using the new file.
HTH
