I am using I4 for fuel logging, i am getting power and ground from the logger input thingy
On the "Config and Download" screen i can see the volts moving around but on the data screen or anyplace else i don't see the values?
I'm not quite sure what you are asking, but have you tried right clicking on a graph in the graphs tab and changing it to the l4 that you are looking for? Also, you have to make sure that the setting is correct for your pressure sender in the config area.
