Jerryl
Tall Unvaccinated Chinese Guy
- Dec 14, 2004
Hello ladies and gents;
I need some advice before going off the deep end . . . . . . . .
Already ordered all hydroboost conversion parts, but stared thinking which usually gets me in trouble. LOL
This all started with a break fluid leak. (Link provided)
The brakes still work fine, no apparent issues. Car has sat for about 4 weeks and the accumulator appears to be holding pressure as the fluid level did not rise in the DS bowl. Since replacing the accumulator a year or so ago, the brake light does not come on.
The Passenger Side bowl does empty from the small leak . . . .and is empty right now. Thought it was the line lock . . . . . but unable to confirm the location of the leak . . . . Forward a few weeks.
Traced the leak to somewhere above the line lock, power master. Appears to be dripping from the back of the motor onto the line lock. Since the system holds pressure (This implies the check valve is ok?), dash brake light does not come on, and brake performance is OK, it now appears to be an electric motor seal leak (?)
Anyone have any insight on this?
