just had a familiar PM incident -
brake light stays on the pedal gets stiff .
looked at the fluid and it was black and looked a bit like a kids science project growing in the fridge
guess a bit of water contamination over time --
a few flush and fills cleared up the fluid and also the problem --
- so what is the reccomendation for brake fluid change intervals -
anyone else run into this ?
my procedure
drain out the fluid put in clean fluid and did the car off brake pump dance.
removed the pressure switch and accumulator to make sure they was no gunk on them or in their holes.
repelat the flush and fill process three times until the fluid is clear after the pump up routine.
-- end --
my procedure
-- end --
