Powermaster Pressure Switch
p&d
I replaced pressure switch as per instructed. Press brake pedal 15 times with key off, and changed it out. Now when i started the car and hit the brakes the brake light comes on then off. The only reason I changed the switch is, it was leaking. Do I need to bleed the brake lines????
Thanks for any help.
I would bleed all the lines and find out.
Start by bleeding the master cylinder itself first. There were instructions on how to bleed it ON the car that came with my A1 unit I just swapped in, but I dont know where I put the paper. Should be instruction on gnttype.org.
