Mark Parks
- Nov 28, 2008
I was going to go for a drive in my 86 GN. When I started it the brake light came on and stayed on. The brake pedal was hard. The reservoir next to the fender was low on fluid so I filled it to match the other side. I took the connection off the brake pressure switch and it was damp with fluid. I presume fluid should NOT be on the connectors? Must be leaking up the switch?
