Powermaster rebuild
I am about to do one. I have the seal kit from Kirpen's . My question is when you press down the inner piston is there a stop where the outer piston move in to get @ the retainer clip ?
What I am referring to is piston guide, that is the one with the retainer clip on it ?
these might help
So the Piston retainer will also move down , too allow the retainer to be removed
Does anybody know if richard clarke still rebuilds these? I heard you can just send them to him and they will do it,also wondering how much it costs. What if you need more than just the seals, any parts available? I have two to get done and one on the car but that one is fine.
Joe,
Kirpen's, It's the Chinese knock off of the future...........:D
Well , I got the one I got off eBay apart.
Do parts 26 (Primary Piston assembly)(two grooves at the end & 23 (reaction piston)(one groove near the reaction disk) get "O" ring(s) on them ? If they do I have the wrong "O" ring kit or I got a different Power master unit
Ok, got the Power Piston apart. The very last piece in there (closest to the pedal push rod) how do you get that out ?
The valve seat? Don't bother. Just leave it. That seal behind there never sees any action anyways.
No O rings on those. 26 has the piston seal on it but that's not included in the kirban kit last time I checked, so hopefully it's still good
thank you for the reply. The "piston seal" you are referring to is # 24 the reaction disk ? Yea, its there a little beat up
No the piston seal is sandwiched between the spring and the piston
These are the 3 piston seals that aren't included in the kit
Sorry I am confused.
Number 24 is there there and there is a good seal on the end of #22
Just clean them up and inspect them for damage it's about all you can do. The Karps kit included these seals but they haven't delivered recently
The the seals , Sorry yes they are all there and in good shape.
Sounds good. Lots of dish soap and hot water to clean everything up, then compressed air to blow it all dry. apply some fresh brake fluid to re-assemble it all.
only time I've ever had one kick my ass was because of some lint / debris on the check valve so I learned then that cleanliness is critical on these units.
