SignUp Now!Hello Anthony. Thanks for your reply. I've had dealings with both Richard and Pete, they are both good people and very knowledgeable. My P.M. has had the "master" rebuilt 2 years ago. It had an "internal" leak. The problem now is the motor takes a long time to "charge" when I replace brake fluid, which I will be doing alot more after reading several posts on the board. Also, I do have the "Powermaster" booklet. And you are right, there is a lot of helpful information in it. But sometimes you just need to "talk to the Pros!" From what I have read in the booklet was that anything more than 15 seconds barring any external leaks, including in the car, then there's a good chance the motor/pump is failing. So now the question comes up, is this something that CAN be "rebuilt? I sure hope so, because there AIN'T no motors to be had, out there ANYWHERE! At least, anyone willing to part with one. I guess I could convert to a "vacuum" set-up, but that is NOT how they were built. Come to think of it, maybe that's not such a bad idea after all. I read some real horror stories of people having their brakes fail at the wrong time! Take care.anything you find should be refreshed so you know what you are starting with. Hydac accumulator balls can be sourced from a variety of sellers from ebay, etc.
That said, contact Richard Clark's Garage (RCG) in Burlington, NC for the refresh / rebuild or outright purchase of a spare PowerMaster unit.
Mr. Clark and John Norton put together a detailed book illustrating the service of the PM unit. If you're thinking of doing the teardown and refresh yourself, that book is a good reference to have.
Thanks Man. I am looking for something in "primo condition." Maybe I should have said that in my original post. Something in "ready to install" condition, without issues. Thanks again...I have 3 cores if you need one.
one just was removed leaking on back cover but all parts were working fine motor pressure switch and accumulator
I even have a new in box reservoir.
Hi Bryan. I appreciate the offer. But I got lucky today. I found a "rebuilt one." It's being shipped to me as we speakI had Pete rebuild a PM for me about 6 months ago as a spare and has not been used. If you need one quickly it is available. He has several more of mine waiting for rebuilds.
Bryan
Back when I still had a powermaster I tried both DOT 3 and 4 with no discernible difference between the two. However, Richard Clark himself recommends DOT 3 in post #10 in this link https://turbobuick.com/threads/brake-fluid-amount.459324/#post-3826654But apparently the recommended "Dot3" fluid absorbs a lot of water! It was suggested to me to maybe use Dot4 synthetic. I need to do a little research before I change things up. Besides, if I did decide to go with something different, I would need to "completely drain every bit of Dot3. Anyway, that will give me something to do. Take care, and thanks...
Hey Chuck. That was awesome! Very simple and quick test. Thanks...Brake fluid water test - Search Videos
Watch videos instantly on Bing—enjoy direct playback, discover related clips, and dive into trending content all in one place.www.bing.com
You know, there is probably some truth to that, especially if Richard Clark makes that case. I'll stick with the DOT3. Some things better as they are. Without trying to reinvent the wheel. Thanks for your input, it's always welcomedDOT3 is supposedly higher viscosity than DOT4, which should be theoretically better for the pump as it should reduce internal leakage. This is just internet banter so take it as such, I’ve never bothered to investigate.
