powerplate ?
charlloots
SMO-CUM
ok guys what is a powerplate ?
wher does it install ?
how hard is it to install ?
how much does it cost ?
thanks for any info .
1. Plenum spacer
2. between the upper and lower intake
3. not hard at all, 30 minutes if you take your time
4. about $60
:D
Use the search feature at the top of the page. You will find a ton of threads on how to do this.
I was very sceptical on the power plate. I have to say it's worth the money. I noticed smoother idle, better throttle response and faster acceleration with it installed and that's with the old design. The newer design is even better.
There are probably already about a thousand posts regarding the power plate. All you need to know though is that they just plain work. :)
here goes
Originally posted by Fuelie600
NEW DESIGN? Do tell!
Jim (turboman38) is using the first version that Jason made and shipped to me. It has one centered hole in the plate whereas the final release plate that everyone runs now, including myself, has the funky shaped holes. I ordered one very early on and when Jason sent me the final release one he said to give the first version to a friend (Jim) as it still works well. There you have it. :)
THANKS FOR THE INFO GUYS . I GUESS IT WORKS AS GOOD ON A STOCK CAR AS IT DOES ON A CAR WITH MODS.
