precision journal bearing play
89mulletbird
How much up and down play should a 6152 journal bearing turbo have?
I have my turbo out and I can wiggle the compressor wheel up and down just a little bit.
I think I'll just keep running it as-is. I couldn't find alot of information on replacing a journal bearing.
Looks like about .010 - .015, hard to shim it because the blades are curved. If it was 0.025 or more it would hit the housing.
Ya, if its .025 - .030 you are gonna need a rebuild. Usually you get some play even when they are brand new. .005-.010 or so. I would recheck your method. Im sure Bison has this down to a science and can guide you with better methods of doing this. If its on the car, I usually do a shim stock style technique. If its off the car, dial indicator with housing off.
I have it off the car. I should be able to put the turbo in a vice and use a dial indicator, but I'm positive it is much less than 0.025.
