SignUp Now!Russ,
How's it working?
Pretty good pressure chart on Lonnies site.
Extreme Automatics Where winning is easy
You'll usually see right at 250 psi max TV with the PR system you have.
They can be measured/monitored while driving. Usually they're measured with the TV cable unhooked from VB/Carb with engine @1200rpm and E-brake on and tires chocked. Cable @ Minimum TV pull and Max TV-Cable fully pulled.
What are pressures at normal idle?
Pressures look OK, I would like to see them a bit higher at full TV, and the idle pressures may be high because of the idle speed.
What is the radius of the TV cable attachment?
That amout of travel sounds like it might be a little short, I had checked mine on a Qjet & thought I had about a 1/4 inch more, but that's only from memory.![]()
