Lee Thompson
- May 24, 2001
Posted earlier about a spare trans I/m trying to build(BQ). Will not shift out of 1st gear @ wot. Finally got around to trying it with a gage installed on windshield. At wot from a stop--pressure goes to 250 psi--at about the time it should shift (5200)-- pressure drops to 100 psi. and it will hit the rev limiter if I don/t lift, shifts when I lift. Tried it with my GOOD BRF VB, Gov. and servo installed, same thing.
I am open to all suggestions.
BTW, this is with an extended pan and extended filter. So I don/t feel it is running out of fluid.
