When I threw a rod in the stock block I replaced the engine with a rebuilt one from ATk Engines for $1,250 back in '97
I see they want $1,500 now so I can see where it's getting more and more expensive to get parts for these cars.
 cars are goin up... new people get in and it just grows ..
FYI...just a short block from Brian @ Gbody parts is $1500.00.
Yep & like TNX his was $3500 for everything needed to do the conversion.
But at $3500 that gave him everything no missing bolts or anything.When you pop the hood it looks exactly like an 87 GN. 50K mile drive tranes are not exactly plentiful anymore.
Only bad thing about an ATK motor you never know what size crank or bore your getting. At least with a low mileage motor from us you know your getting std bore & std crank.
T-Type to answer your question the rear is the same & an 84 GN trans will bolt up. 86-7 Trans is the ideal situation though.
1500 for a turbo motor? how many miles have you gotten out of it?
So you guys have low-mile motors for sale? If so, do you ship them? If I buy one, it comes with everything I need (I mean everything)?
How much would one run me shipped without a transmission?
Thank you.
Any of the bolts that were removed were bagged and labeled, I had Bweavy install me a new cam and lifters as well. The only thing you will have an issue with is where do the studs go opposed to the bolts. So I called gbodyparts, they ran out and looked at an engine and told me where the studs were and where the bolts were, piece of cake.So you guys have low-mile motors for sale? If so, do you ship them? If I buy one, it comes with everything I need (I mean everything)?
Thank you.
