JuicedXtreme
- May 26, 2003
Sup
I went yesterday to the dyno and i had both stages ( dry/wet) of nitrous connected to the dfi so it can activate them using the rpm and tps options etc.. Well when i tried the dry shot only it was cutting on and off . So i put the 2nd stage on ( wet ) and turned the dry shot off and when it activated it did the same thing like cutting on and off . So i removed the wireing from the dfi and i wired it to my WOT switch and i raised the VE table where it goes to WOT to make it rich and when i activated the dry shot it ran great and rich . So i don't know whats happening . When i put the wet shot too it worked great . Did anybody else had this problem ?
On the nitrous settings i had the tps enable at 90 % and disable at 85% , the rpm to enable at 3000 rpm and disable at 5700rpm and on the MAP box i didn't use that option . Maybe it isn't giving a good ground to the relay ?
Well the truck made 404 rwhp/435.6 rwtq so i'm happy but i would like the dfi to control the stages for me .
thanx
thanx
