Feb 22, 2013 #1 W Warped No helmet required! Joined May 25, 2001 Messages 559 Seldom do they work immediately when you select low or intermittent. If you leave them on either of these settings they will eventually work. If you select the high setting they will work immediately. What do I need to replace? Thanks.
Feb 22, 2013 #2 E earlbrown runs with scissors Joined May 26, 2001 Messages 7,539 Your patience GM wipers rarely move immediately when you put them on intermittent.
Mar 25, 2013 #3 G Gunmetal87 Member Joined Aug 12, 2012 Messages 213 I was courious about this also. If it was the wipper motor or intermittent housing. Did a search on the web and found this about trouble shooting. http://www.elcaminocentral.com/showthread.php?t=27163
