problem
bigtomey
turbo went bad and went to go get oil check and there was gas in the oil can someone give me an ideal what happen
Gas in the oil made the turbo go bad. Leaking injectors? Vandalism? (had a mechanic actually try that). If it was a lot, there's a good chance everything is worn pretty good.
prime the motor a few times by turning the key to the on then off postion like 5 times then pull the plugs and see if any are wet.
