Coelacanth
- Jul 7, 2014
It's leaking from just below the 16mm hex fitting that threads into the bottom of the FPR. I didn't see any leaking at the horizontal press-in fitting that presses into the fuel rail...so that would be the smaller O-ring, from what you described. Red arrow shows exactly where it's spraying from; between the fuel line and 16mm fitting.
EDIT: This topic seems to also cover this O-ring, and you replied with the important info there, too. Thanks!
https://turbobuick.com/threads/o-ring-or-no-0-ring.448225/
