I am trying to work out the bugs of the converting to the vacuum brakes conversion . I intially T into the pvc line but my car would not hold idle . It would run for a little while and shut off . I also had a very hard brake . I bought the TTA vacumm block and turned up my idle . The problem now is that the motor idles to high when I start it up so I turned the idle back down .
If I plug the line that goes to my Vacuum canister the car will idle . A friend told me to get a check valve and that will solve the problem .
The other problem is that my rear brakes cylinder is only pushing the front of the shoe . I thought vacuum would be the way to go but I have been having nothing but problems since I have started the conversion . I am starting to regret that I didnt stay with the power master . As I said in other threads Red regal has been nothing but patient and helpful . Trying to get this system to work is wearing me out . I cant tell if my problem is the booster master cylinder or both . I cant keep enough vacumm to trouble shoot . I now feel like a dog chasing his tail . Three weeks and I have not gotten this thing sorted out .
